#11 Re: mini truck datsun
ed74mnd Posted on: 2011/8/19 13:47
Big wheels, extend the sill panels down 2-3 inches for visual effect, static lowered getting some good effect without significant or dangerous subframe mods.
you could run a reduced leaf rear and bag it.. not great but it could work...
my other ute...bike hauler... lowered but not bagged or made stupid...
#12 Re: mini truck datsun
ZigZag Posted on: 2011/8/20 0:10
mini trucks are wicked
#13 Re: mini truck datsun
mradtee23 Posted on: 2011/8/20 12:31
get a hilux, dont cut up a datto for this...
#14 Re: mini truck datsun
Unv-Ute Posted on: 2011/8/24 8:29
half way there ive just finsihed drawing a custom chassis for it and i can get 4x4 diff stuff easy or make it
#15 Re: mini truck datsun
shakn-1 Posted on: 2011/8/28 23:48
ive had 4 minitrucks now 2 bagged, id recommend a static bag setup... put ya blocks and reset springs in so it sitts on the diff then weld in some bag brackets between the diff and chassie. go from stock to dumped and keep the ride quality. and its easy to return to stock when the po po catch ya!
i has the setup on this one
jpg  Picture.JPG (23.25 KB)
15374_4e5ac5927f075.jpg 432X288 px
#16 Re: mini truck datsun
Unv-Ute Posted on: 2011/8/30 12:24
cheers for the info dude was it expensive to set up if u did most of the work
#17 Re: mini truck datsun
shakn-1 Posted on: 2011/8/30 23:21
if your good with a welder then na.
you can buy cheap gear from mex's garage
will need
bags (re7's are good),tank,valves,lines,wire/switch
which you will get if you just buy a rear kit.
bit of acrappy sketch for ya
jpg  IMG_1496.jpg (22.20 KB)
15374_4e5d621cb6394.jpg 615X461 px
« 1 (2)
