lowered leaf springs swap-able?
Do leaf springs from coupe fit in a ute and vice-versa?
Tech Wiki isn't clear on this. Thanks.
Posted on: 2011/8/29 12:45
Re: lowered leaf springs swap-able?
From Ringwood, Melbourne, AUS
As far as I know they are all the same lencth, it is just the thickness and number of leaves that differs..
Utes are designed to carry more load so have more/thicker leaves.
Posted on: 2011/8/30 0:43
Deano
From Sydney NSW
Does this mean you could lower you car with ute springs, but use less of them? Because they will be stiffer.
Posted on: 2011/8/30 3:06
related question.....does reseting the rear leafs on a ute require different shocks than the stock ones?
Posted on: 2011/8/31 1:10
Ute springs have one additional helper spring that is short and stiff, it's a load sprung at bottom of the pack. So sedan and coupe have 3 and ute has 4
Posted on: 2011/8/31 1:55
From mandurah
Whats the go with flipping the eyelet leaf ?
can i just flip it and put it back in or will there be a chance the spring will break ?
Posted on: 2011/8/31 4:42
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
That one I didn't want to touch as I thought same thing
Posted on: 2011/8/31 5:14
When the eye is flipped they actually heat the eye and rebend it under the spring, that way you still have the same curve etc in the spring but it is now mounted approx an inch lower.
Flipping the eye isn't a DIY thing, it needs the right gear and people to do the job, after heating and bending the eye it needs to be re-tempered etc.
Anyone that can reset leafsprings should be able to flip the eyes.
As versus just flipping the whole spring pack over which is just stupid dumb..
Posted on: 2011/8/31 7:34
Deano
From mandurah
Ok ,thanks deano ,so would the maddat ones be the go ? ,and does anyone know how far stock springs can be reset ? Is there a limit ? I want ro get rid of my lowering block so need to have the springs reset by 3 or 4 inches ,4 would be nice cos the tyres would juuust start tucking under the rear :D
Posted on: 2011/8/31 7:45
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
The benefit of flipping eyes is that you lower the car while still having an arch in the springs, if you then reset the leaves lower you will loose some arch but mot as much as without flipped eyes.
I guess the limit depends on how much travel you have before bumpstops come into play.
Posted on: 2011/8/31 7:57
Deano
