#1 Wanted ,MIG welder to borrow ,Perth
estyre Posted on: 2011/8/29 7:55
As above I need a mig to fix some stuff on my ute
Only needs to weld the top rear mount/tabs back on my gaurds and weld a nut on the bottom of the sill for my gaurds to bolt to as the threads are gone
Ring or txt 0437787966
Cheers
#2 Re: Wanted ,MIG welder to borrow ,Perth
Posted on: 2011/8/29 9:23
Grab niges stick I mean mig
#3 Re: Wanted ,MIG welder to borrow ,Perth
levey Posted on: 2011/8/29 10:45
Do it at Damo's house when you go there.
#4 Re: Wanted ,MIG welder to borrow ,Perth
Posted on: 2011/8/29 11:00
Playing with stdick or a welder- both?
#5 Re: Wanted ,MIG welder to borrow ,Perth
old_school Posted on: 2011/8/29 12:08
Drop round and do it here if you want.
Got my new MIG up and running.
#6 Re: Wanted ,MIG welder to borrow ,Perth
estyre Posted on: 2011/8/29 16:49
awesome fellas ,jarrad if your free this coming weekend ide love to do it !
When ever your free let me know and we can arrange something :D
#7 Re: Wanted ,MIG welder to borrow ,Perth
Posted on: 2011/8/29 21:44
Pop that cherry.
If you had gas and in melb youcould borrow my mig
#8 Re: Wanted ,MIG welder to borrow ,Perth
reuby_tuesday Posted on: 2011/8/30 1:45
Jesse, you can come up here and use my mig, or can borrow my gasless unit if you like. You should have asked on the weekend. Hec if you are keen, you can borrow my Mig unit, or the TIG, but you have to go and pick that up and then deliver it to me as part of the deal. Hec the stick welder is here to borrow if you are keen.
Jesse, if you want to make a weekend of it, you can drive up and we can have a good crack at it.
Yellow peril can lift the ute up onto blocks too!
I dont have a plasma cutter yet though, so it will have to be oxy or hand cutting for the steel patches.
#9 Re: Wanted ,MIG welder to borrow ,Perth
estyre Posted on: 2011/8/30 4:40
Awesome ,ive got a cig stick so just need a mig
Will see when im free fellas
#10 Re: Wanted ,MIG welder to borrow ,Perth
reuby_tuesday Posted on: 2011/8/30 10:21
180-250amp CIGweld single phase welders come up every now and then second hand for next to nothing. You can run gas/gasless wire thru them as they have swapable polarity so no need for gas if you are a cheapskate.
Around $500 should get you a one in good working order ready to go.
