« 1 (2)
#11 Re: Winton Sprint Sept 10. practice on the 9th.
D Posted on: 2011/9/11 3:44
Well done Simon, its not all that but good to
see a $100 dollar turbo do what the expensive
one couldnt do :)
#12 Re: Winton Sprint Sept 10. practice on the 9th.
LAGWAGON Posted on: 2011/9/11 6:53
nice work simo, i think that record was an sr non turbs?
time in the seat will see the times drop i reckon
#13 Re: Winton Sprint Sept 10. practice on the 9th.
sikyne Posted on: 2011/9/11 7:49
The car needs a little more neg camber at the front and either more rear spring or a small rear anti roll bar. It picks up the inside front wheel too much.
You`re spot on Leigh, I think there is a couple of seconds in the car without changing anything.
I cant wait to get back on the track again.
D, The secondhand turbo is holding together. Ive been a bit lucky with it realy. If i have enough money i`ll do the turbo upgrade before heading out again.
#14 Re: Winton Sprint Sept 10. practice on the 9th.
bobthebuilder Posted on: 2011/9/11 10:47
Great effort Simon.
Well done on continually working on your little beast.Most guys turn up check tyre pressures and thats the extent of their pit activities.
My Racecar's day ended early with a broken watts linkage but is starting to show signs of being quicker with new brakes and a bit of tweaking.
Must make mention of Ebony's effort down there .She improved her times from 2.12s down to a 1.54 in the little ute. Bloody great effort for a 16 year old at her 1st dry attempt at Winton
Roll on the twilight meeting.
Cheers
Bob
#15 Re: Winton Sprint Sept 10. practice on the 9th.
Posted on: 2011/9/11 11:02
great stuff by all of you for getting out there. impressive improvement from your daughter bob. what were your times in the ute there? few more outings they may be under threat
so 1:40 to a 1:37, a12t to sr20de... is day thats oretty damn good simon. if you get close you got to be doing 1 hell of a job at it.
#16 Re: Winton Sprint Sept 10. practice on the 9th.
trb012 Posted on: 2011/9/14 0:18
Some quick times there boys. Im heading back in October with the old mans corvette club Hoping to crack into the mid 1.40's
« 1 (2)
