L18 I totally agree about autospeed not differentiating beetween the setups. Note that is why I made sure I did.
I also agree that people belive what they see, as if it was the gospel. I relate it to The Fast and the Furious. people see it and think man thats the best I gotta have that.
I also understand and belive what you are saying of 3 exhaust pulses of a specific value over a specific time frame is more ideal than that of 2 exhaust pulses of the same specific value over the same specific time frame
But to give tha argument this:Quote:
The argument does not apply to 4cyl cars. A turbo works by the turbine being driven by exhaust gasses - obviously enough. But when you halve the number of cylinders feeding each turbo, you not only halve the total flow over the turbine, you have also made it operate on the turbine for half the time. Not big problem if you started with a 6cyl, but not so good if it was a 4cyl. Ever heard a V twin bike running? Nice way to drive a gas turbine huh? Between each pulse that is working on the turbine, there are the forces of friction and load on the impellor working against it's motion with only the spinning assembly's inertia to try to keep it going. Being so small, it has bugger all inertia working for it, so the turbine slows, then another exhaust pulse hits it and has to stop the decelleration before accellerating it again. That is not only bad for performance, it also mean reduced turbo life.
Thems horse's apples.
Thats like me saying running a turbo off 3 cylinders is worse and its going to limit the turbos life as compared to running it off of 4 cyl's for exactly the same reasons as you stated.
Yeah there is more time frame inbetween the pulses of 2 cyl's when compared to 3 cyl's but the same goes for 3 when compared to 4.
With the correct sizing this can be overcome.
This will indeed make the turbos spool up as quick or quicker depending on sizing, and yes it will limit top end with this sizing vice-versa.
Either way 2 or 3 cylinders isnt going to give the benifits of sequential twin setup.( bottom and top end)
Yeah its not an ideal setup but to say no factory has done it and thats why 3 is better than 2, Is a joke.
But you did agree your thoughts are that of if the factory hasnt done it, it must not be possible.
Maybe this topic has gotten of subject abit.
Back to the real subject
Ultimately if its single or twin setup you will either have bottom end or top end power depending on sizing. Unless it is a true sequential twin turbo setup.
