« 1 (2)
Re: 1.3B Mazda engine in datsun, possible?
From Arlington, TX, USA
barpk wrote:
What about 85-88 Honda Accord's A16A(1598cc) can it b fitted on to 1200 gearbox?
Hondas engines won't work in a RWD set-up. All Honda engines (except a few new ones) spin backwards. You would have 1 forward gear and 4 reverse gears.
Posted on: 2004/2/26 3:27
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Good point. Yet it could be done, the key is a reverse-cut camshaft.
But I doubt if barpk wants to re-engineer the engine or gearbox.
Posted on: 2004/2/26 3:39
From Pakistan
i guess i have to forget any engine for now :(
its hard to believe but there r no engines 1.3litre plus in Pk. that came in RWD forms, older L-16 r almost non existent, nissan has fwd E13 only or GA14.
can E15 b fitted on 1200 GB with adaptor plate?
and thanks for info.
Posted on: 2004/2/26 9:47
STRONG IS STRONGEST ALONE. PERIOD
Yes, reportedly the E15 can be fitted to the rwd gearbox with some modification: E series OHC engine swap.
But barpk, you will have to do it yourself, no one here has details on how to do it. (they didn't write down the details back when it was done).
Posted on: 2004/2/26 17:53
« 1 (2)
