#11 Re: EOI- Fully Built A15, Twin 40mm Dellortos etc
MY110 Posted on: 2011/10/9 22:05
Hey Dion, sent you a PM- SU's = smooth and responsive on a mild motor, Webers/ Dellortos = power on a worked motor.
This motor is a bit beyond SU's in my opinion they won't work due to the large cam size. Also you would need a GX- SU manifold for the SU's to bolt up to this motor as its ported to GX inlet port size.
Hope this helps Cheers Matt
#12 Re: EOI- Fully Built A15, Twin 40mm Dellortos etc
BigD Posted on: 2011/10/10 3:19
Hey Matt, good luck with the sale. I wonder what motor your going to put in the coop next?
I have seen this A15 engine go on a datsun cruise i went on. i was cruising in i think (Deions 120Y) looks the same, is that Trav's 120Y he sold off ??
Anyway good shell and good motor. if you need to keep it learner legal then this motor will keep you happy for a while.
#13 Re: EOI- Fully Built A15, Twin 40mm Dellortos etc
Dion120Y Posted on: 2011/10/10 6:21
not sure if i bought it off a trav, bought it over a year ago now, from Glebe, didn't get to talk to the owner only his brother,
how much power is this engine making now do you know??
Dion
#14 Re: EOI- Fully Built A15, Twin 40mm Dellortos etc
BigD Posted on: 2011/10/12 3:23
I believe Matt has this motor running now so you can see/hear it before he pulls it out and from memory it has been dyno tuned so if your keen get on to him and see what specs you get.
« 1 (2)
