Re: Struts
51mm would be stanza/200b or similar and 46mm or so would be the smaller struts as per wiki.
What's your 1200 running stefano? A series or plans for some thing more? Good thing bout these are the coil overs as long as the insert has a shorter stroke too so you can lower the car easily.
If they are 120y, then the s13 brake converion would also be worth while.. Look piggy I finally learnt stuff from you
Posted on: 2011/10/9 22:04
Re: Struts
From Adelaide, Australia
I'm running an A14 so nothing too silly. I'll try to measure the diameter in the next couple of days...
Posted on: 2011/10/10 2:11
1200 ute money pit
Re: Struts
Disk anything way better than drums
Posted on: 2011/10/10 3:09
Re: Struts
They're about 45mm
Posted on: 2011/10/10 8:45
1200 ute money pit
Re: Struts
Probably coupe ones then. Could be 120y but they are the small struts.
Posted on: 2011/10/10 9:16
Re: Struts
Oh did you get the adjustment spammers with them too? Hope so other wise it's hammer and screw driver time.
I always wound mine right down to take out and reinstall, means no tension on spring so heaps easier to bolt in the set ride height- it's Good to mark where the thread lock nut is so you can get to same ride height again
Posted on: 2011/10/10 9:20
Re: Struts
Nope, no spanner
So what brake options does this give me?
Posted on: 2011/10/10 9:21
1200 ute money pit
« 1 (2)
