Browsing this Thread:
1 Anonymous Users
Re: wheel size |
i have 14 x 7 and when i take a banked corner like a freeway on ramp my tire hits my strut
Posted on: 2011/10/19 2:27
Re: wheel size |
Not too shy to talk
^What's your offset? My actual wheel comes no where close to the strut but the tire (205)bulges out quite a bit from the rim. You may just need a fender roll and a 3mm slip on spacer.
Posted on: 2011/10/19 23:26
Re: wheel size |
where can i find wheel spacers
Posted on: 2011/10/20 1:23
Re: wheel size |
Not too shy to talk
Wheel shops or really anywhere that sells parts for cars. I got mine for 10 bucks at a wheel place down the street from my shop. They are just a universal slip on 4x114.3 10mm. I had to hone them out a bit to get them to clear the grease cap but it was minor. I wasn't really worried about hub-centric or anything it was more of a temp fix.
Posted on: 2011/10/20 22:28
Re: wheel size |
Quite a regular
im using 195/50 15's on trx wheels on my 1200 ute but unsure of rubbing as im using 200b discs, stanza ball joints and custom coilovers and wouldnt know about std gear like struts because of my 65mm od springs
Posted on: 2011/10/23 7:01
Re: wheel size |
Measure the strut diameter if your using 200b brakes should be 51mm and mostlikely stanza or 200b.
With coil overs shouldnt rub on the struts at all on fronts, unless on the guards
Posted on: 2011/10/23 12:09
Re: wheel size |
Quite a regular
only missing adjuster on strut by 20mm without spacers, and have no trouble rubbing on anything
Posted on: 2011/10/24 11:34
