#11 Re: wheel size
420 Posted on: 2011/10/19 2:27
i have 14 x 7 and when i take a banked corner like a freeway on ramp my tire hits my strut
#12 Re: wheel size
SakuraGarage Posted on: 2011/10/19 23:26
^What's your offset? My actual wheel comes no where close to the strut but the tire (205)bulges out quite a bit from the rim. You may just need a fender roll and a 3mm slip on spacer.
#13 Re: wheel size
420 Posted on: 2011/10/20 1:23
where can i find wheel spacers
#14 Re: wheel size
SakuraGarage Posted on: 2011/10/20 22:28
Wheel shops or really anywhere that sells parts for cars. I got mine for 10 bucks at a wheel place down the street from my shop. They are just a universal slip on 4x114.3 10mm. I had to hone them out a bit to get them to clear the grease cap but it was minor. I wasn't really worried about hub-centric or anything it was more of a temp fix.
#15 Re: wheel size
DISMO Posted on: 2011/10/23 7:01
im using 195/50 15's on trx wheels on my 1200 ute but unsure of rubbing as im using 200b discs, stanza ball joints and custom coilovers and wouldnt know about std gear like struts because of my 65mm od springs
#16 Re: wheel size
Posted on: 2011/10/23 12:09
Measure the strut diameter if your using 200b brakes should be 51mm and mostlikely stanza or 200b.
With coil overs shouldnt rub on the struts at all on fronts, unless on the guards
#17 Re: wheel size
DISMO Posted on: 2011/10/24 11:34
only missing adjuster on strut by 20mm without spacers, and have no trouble rubbing on anything
« 1 (2)
