(1) 2 3 »
quick change alloy diff :-D
From ACT Aus
so not sure who will appreciate this but i have a winters diff currently in the mail for my ute, a 7" quick change with alloy centre hubs etc, will weigh approx, 55kg fully assembled, can take 350hp+ and can change the ratio in 2 minutes, i ordered 2 sets of ratios, 3.8 and 4. 6 hahaha get some power out of anything with a 4.6 :D
ordered with a wedgelock lsd but also got the adaptor for an extra $20 which will lock it in the time for an axle swap, half an hour.
3950, delivered, dunno if customs will bust my balls yet, another $400 i guess
will post pics once its in
Posted on: 2011/10/22 13:41
Re: quick change alloy diff :-D
From mandurah
Sounds awesome ,what brand is it?
What motor are you putting in front of it? Angry A series???
Posted on: 2011/10/22 14:45
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Ive been saying for 11+ years this would be the
ultimate rear end for a datto due to weight/strength.
You are like the first man on the moon! congratulations!!!!
Posted on: 2011/10/22 14:47
winters is the brand name, there a tuff diff. did you get axles and everything for that price?
Posted on: 2011/10/22 14:54
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Rods been using quickchange for years but
datto folk never spend that much usually
and for the price of some of the R31 setups
available a QC setup is 10 times better not
to mention 30kgs lighter.
Posted on: 2011/10/22 14:59
From ACT Aus
haha thanks guys yeah it's a winters. and yeh that price includes axles, hub assemblies, 2 rotors and 2 sets of quick change gears.
unsure about a motor yet, thinking either worked n/a ca18 or a 4ag 20v, but it's already got a ca20 in it so ca18 swap will be heaps easier, and with some quads, 4-1's more compression etc should be a pretty decent engine.
other option is ca turbo but i kind of want that tough n/a response
Posted on: 2011/10/22 22:38
unfamilia wrote:
You have bump stops? Your soft
Ca18 will be way easier for you and with some decent na builds out there would be more than enough.
That said for less $$$ you could have ca18det in there and more power
Posted on: 2011/10/22 23:27
Youve gone that far on the diff you might go as far on
the engine and get the lightest and most powerful NA
possible either full mechanical head SR20VVL or my fav
the QR25DE with modded cheap SR20DE factory full counter
weighed forged crank for a QSR23DE. Both will make over
200hp with little investment but VVL is available at
my105.com but sites down at moment fully developed except
throttle bodies too small using 4ag ones.
Posted on: 2011/10/23 0:15
Go ca, cars already set up for ca, why give your self more hassles. If it's engineered with ca, should be no issue with another ca in there
Posted on: 2011/10/23 1:37
From Ballarat Victoria
Id love to see it when it gets here, be worth a drive i think.
I wonder how much my H165 ute diff assembly weighs?
Posted on: 2011/10/23 2:20
VIC DYNO HIRE
(1) 2 3 »
