help needed to wire tacho!
From vic
hi just needed to know were these wires go for a 120y tacho it originaly came with a clock.
jpg  2011-10-28 15.13.24.jpg (60.53 KB)
14954_4eaa2f7f0a6a4.jpg 461X346 px
jpg  2011-10-28 15.13.55.jpg (193.64 KB)
14954_4eaa2f93684c5.jpg 963X722 px
Posted on: 2011/10/28 5:29
Re: help needed to wire tacho!
From Snohomish, WA USA
Just plug and go. Your 120y should have the standard wire harness for the tach under the dash. Mine did when I found a tach for it. Just look for the wires.
Posted on: 2011/10/28 6:29
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From vic
Nice i will check it out.
Thanks!
Posted on: 2011/10/28 7:25
Quite a regular
just double check where thos black/white wires go because how the 120y and 1200 tacho's pick their signal up is from the coil current in series or going through them instead of just being picked up off neg coil like most modern tacho's. but like whats just been said shouldnt be able to go wrong with standard factory wires.
Posted on: 2011/10/28 8:16
Should just plug in. I had that exact same tach for my B210 here in the states. Just look under the dash. You should see the terminals.
Posted on: 2011/10/28 11:19
'73 2 Door Sedan
From Brisbane
wish it was that easy on mine :(
never could find anyone to tell me how to wire up the stock tacho, to my haltech ca18 :(
Posted on: 2011/10/28 23:16
