Re: how to wire ca18det
From Trinidad
I checked the coil pack for battery voltage.. good
I checked for continuity on ground circuit .... good
I removed all injectors and cleaned them .... doubt all 4 are leaking
changed the plugs again last night and the car ran like a beast for about half an hour and then started to run on 3 cylinders.. pulled all the plugs and all were black and fowled... any other advice? also someone was telling me that it could be the air flow sensor... I checked it against the factory service manual and it's within specifications ... running out of ideas here guys
Posted on: 2011/10/30 20:55
Subject Poster Date
     how to wire ca18det mikeyr 2011/10/26 13:58
       Re: how to wire ca18det demacoz 2011/10/26 23:26
       Re: how to wire ca18det mikeyr 2011/10/27 23:46
         Re: how to wire ca18det dattodude 2011/10/28 8:27
       Re: how to wire ca18det mikeyr 2011/10/29 2:19
         Re: how to wire ca18det dattodude 2011/10/29 12:01
       Re: how to wire ca18det mikeyr 2011/10/30 20:55
         Re: how to wire ca18det 1200rallycar 2011/10/30 23:41
           Re: how to wire ca18det ___1200ute 2011/10/31 4:44
       Re: how to wire ca18det DAT012 2011/10/31 8:14
       Re: how to wire ca18det mikeyr 2011/10/31 14:35
       Re: how to wire ca18det datto13b 2011/11/3 20:49
       Re: how to wire ca18det mikeyr 2011/11/8 0:55
         Re: how to wire ca18det 1200rallycar 2011/11/8 1:37
