so you think the way a turbo works is by restricting the exhaust flow in the manifold until it reaches a high enough pressure to start spinning the turbine???
No, If you read my post you would reaslise I didnt say that.
I said;
Yes a turbine is a restrictor.
At low engine rpm the gas volume being produced can easily pass through the turbine unnoticed.
( so at low rpm it isnt restrictive to the flow of exhaust gases )
But as engine rpm increases, this gas volume being produced is being produced to quick to pass through the turbine unnoticed.
( there fore the turbine has become a restrictor )
The gases are still passing through the turbine but because the flow is restricted to how much can pass through the turbine, the gas volume which is continuing to increase in the exhaust manifold is increasing pressure.
This pressure forces gases through the turbine. Because it is being forced, flow through the turbine is faster.
Because the gases are being forced through the turbine, the turbine begins to spin faster.
Do You Understand?
If the turbo has to be restricitve at low rpm to get it on boost, heaven help you get all the gas out of the engine when the thing is doing 6000rpm and 12psi!
Is it not true;
If you use a smaller turbo it will make boost at low rpm with this compromising top end power,
and,
If you use a big turbo it will make boost at a higher rpm with this compromising down low power.
If you use 2 cylinders you will need a small turbo for it to spool up at (lets say) 1200rpm.
Now if you use 4 cylinders you will need a turbo twice the size for it to only begin to spool up at 1200rpm.
Now if the turbo on the 2 cylinders becomes too restrictive and can't flow enough gases at ( lets say ) 6000rpm
You seem to think the turbo running off 4 cylinders wont be.
We are talking size for size.
Now think about what you wrote here;
and somehow when "when the turbine becomes a restriction for this volumes flow, flow will be increased "??? Bugger me, the way to increase flow is to place a restriction in its path - that's where I've been going wrong all these years...
Yes the turbine can become to restrictive, this is why top end power is compromised on a smaller turbo.
Is it not true that ( lets use a workshop compressor and air blower as example ) the greater the pressure inside the compressor, the more air will flow out of the air blower quicker?
huh? so did you or didn't you get the improved low end response or not? - ie more boost at a given rpm at low speeds...
If the short manifold starts spooling up at 1300rpm this means its creating boost from 1300rpm onwards
If the j pipe manifold starts spooling up at 2100rpm this means its creating boost from 2100rpm onwards.
I know it might be hard for you to read since its such big words and numbers but if the short manifold starts spooling at 1300rpm and the j pipe starts spooling at 2100rpm this means the short manifold had better low end response.
If you want to be stupid and get technical I can tell you in actual fact this turbo on both manifolds, was spinning at idle ( 800rpm ) but it didnt begin to spool quicker and create boost untill the engine reached the rpm figures I wrote above.
Cheerio Steve
