Re: brake upgrade
From WA
the springs on the stanza struts will need lowering by 43mm under a 1200 to get an even ride height.
Posted on: 2004/3/3 9:58
Re: brake upgrade
From EUPEN / BELGIUM
feral wrote:
Also stanza struts allow the 270mm 240Z brake upgrade with sumitomo calipers.
Why is the 270mm upgrade only posible whit Stanza struts. Isn't it possible to do a brake upgrade using the OE B110 strut?
Wilwood have calipers for direct bolt on the strut, mount center as 3.50 just as the OE strut. They also have caliper mounting brackets for radial caliper allowing bigger rotors. Or why not make a bracket by its own that suits the OE strut mounting and give enough space for bigger discs?
Is there something wrong with the OE strut, is it to weak for this kind of mod?
Posted on: 2004/3/3 21:38
Belgian Roadster
SRL 311 69'
1200 SR20DET swap started
« 1 (2)
