In the United States:
* you can get strut cartridge inserts (shocks) and coils springs by posting a message in our Classifieds. In other words, buy some good used parts. Coil springs don't usually go bad, however. If one side is sitting lower than the other, there might be something wrong.
* Quickor Engineering will build you a set of custom springs. They are not listed in their catalog, but I've spoken with them and they say they have the specs on hand and can make them on request.
* Possibly you could cut-down B210 or B310 springs to fit. B110 is 110 mm diameter and the newer ones are 100 mm but they might fit. They are 45 mm longer. Most other Datsun springs are much larger in diameter.
* As of 8 Nov 2011, brand new strut Insert shocks (original wet type) are for sale at
Classic Garage. These are Koni brand.
* Some 1200 owners use VW Golf inserts, such as Bilstein part number W0133-1604944. See
VW Rabbit InsertsNewer strut inserts, including North America B210 strut inserts, are probably too big as they use 50mm diamater struts, while B110 uses 45 mm struts.
