« 1 ... 15 16 17 (18) 19 20 21 ... 42 »
Re: 1200RallyCar - My road car rebuild - 1200 coupe
Isn't tiramasu in nz??? Titamaru wherever it said
Posted on: 2011/11/6 13:21
From Melbourne, Australia
wow, not mine but similar, hard to tell due to quality but does that even have flares too?
had the car on a hoist at a mechanics this morning, have organised for him to weld a second set of tunnel mounts in and modify the gearbox crossmember to suit (will be a H-shape) that way it will be all contained inside the tunnel to allow maximum exhaust room, and suit the engineers requests
then i get to put in a sweet exhaust instead of the hack job that we used to get it running
Posted on: 2011/11/7 9:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Didn't Sanjay like the pea shooter
Posted on: 2011/11/7 10:13
he doesnt care, but it does need a cat in it,
planning to get a 2.5 inch mandrel bend system
did some dodgey adaptions and use of step down reducers to get the car going, but dont want to get a proper system till the gearbox x-member is sorted
Posted on: 2011/11/7 10:30
1200 Coupe Rallycar
Keep the reducers for EPA db reading you will need 89fb yeah with ca? Mine was still the Ol
96db... And I still struggled til Subaru muffler went in
Posted on: 2011/11/7 12:52
engine crossmember - done
gearbox crossmember - done
exhaust - soon
then
-charcoal canister
-reinforce front seat brackets
-change brake master
-check list for anything else
Posted on: 2011/11/11 10:12
1200 Coupe Rallycar
Have you decided where to put your charcoal canister. As my ute is an 85 model it came with one fitted to the passenger side strut tower,however with the fitting of a skyline airfilter box that space is now gone. I'm looking for inspiration as space is at a premium.
Make sure you post a pic.
Posted on: 2011/11/11 12:00
Have you gOt any pictures of you gear box mounts and contained tunnel mount points mick? Will be interested to see
Posted on: 2011/11/11 21:37
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
will try to get pics, tried to do gearbox crossmember already but need the car up on four stands to get anywhere near it.
havent even got a charcoal canister, but am thinking under the gaurd might be the go, think tomoz did it with his (or at least he did put the air inlet there), might search for that now for inspiration on that one
wow tried to show someone an engine bay pic today and discovered i dont have any engine shots for ages, so will get some of them too
just sat in maccas drivethroguh for a good 10-15 minutes waiting for my mc happy day big mac, temp didnt even get to 80 with puegot 505 side tank rad and 12" thermo, very happy with that!
Posted on: 2011/11/12 10:18
1200 Coupe Rallycar
tried to get gearbox x-member pic again today... no great success
engine bay shots from today
ended up having a custm engine mount made
engine sits 35-40mm from firewall, with enough room for stock heater hose locations to be used
Posted on: 2011/11/13 8:29
1200 Coupe Rallycar
