how to - speedo with CA18DET, skyline stumpy box?
From Melbourne, Australia
howdy, as per title, want to setup speedo with skyline stumpy box, spotted that it has a mechanical output drive... does the 1200 one fit it? i see mad dat sells a conversion cable but as it says you need to exchange the electronic sensor, i guess its for the silvia box...
do i need the mad dat cable or does it not suit stumpy box?
Posted on: 2011/11/12 10:45
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: how to - speedo with CA18DET, skyline stumpy box?
From Geelong, Vic
still my box?
if so it should have a sender in it. use that and a 200b speedo cable. will suit the box and should fit the dash. some late dashes have issues with it and you have to trim the end of the speedo cable down as the speedo gets stuck, or just leave the cable loose in the back of the dash
Pretty sure for the silvia box, or boxes with the speedo output on the drivers side, you just use a 120y cable
Posted on: 2011/11/12 11:22
yeah still your box, looking for a 200b speedo cable then
Posted on: 2011/11/13 3:16
1200 Coupe Rallycar
