front strut for bigger brakes
From EUPEN / BELGIUM
feral wrote:
Also stanza struts allow the 270mm 240Z brake upgrade with sumitomo calipers.
Why is the 270mm upgrade only posible whit Stanza struts. Isn't it possible to do a brake upgrade using the OE B110 strut?
Wilwood have calipers for direct bolt on the strut, mount center as 3.50 just as the OE strut. They also have caliper mounting brackets for radial caliper allowing bigger rotors. Or why not make a bracket by its own that suits the OE strut mounting and give enough space for bigger discs?
Is there something wrong with the OE strut, is it to weak for this kind of mod?
Posted on: 2004/3/4 20:26
Belgian Roadster
SRL 311 69'
1200 SR20DET swap started
Subject Poster Date
     front strut for bigger brakes belgian_roadster 2004/3/4 20:26
       Re: front strut for bigger brakes sunny 2004/3/5 14:42
         Re: front strut for bigger brakes ddgonzal 2004/3/5 17:10
           Re: front strut for bigger brakes belgian_roadster 2004/3/5 22:05
