#1 A15 cuts out
terryearl Posted on: 2011/11/13 16:54
running a 1488cc A15. the engine will cut out suddenly and randomly at all speeds and at idle.a buzzing noise can be heard from the relay area. i think i'ts coming from the auto choke relay?? i think the wiring to choke may be incorrect as it's fed from the ballast resistor and not the coil. anyone knoe how it should go? thanks
#2 Re: A15 cuts out
ddgonzal Posted on: 2011/11/13 19:37
The relay should be fed by 12V. See if that resolves the problem.
#3 Re: A15 cuts out
terryearl Posted on: 2011/11/13 21:27
ok. thank you,it used to run from coil ig+ and now it's running from the ballast resister. i'll change it and see what happens.
#4 Re: A15 cuts out
Datsmithy Posted on: 2011/11/14 8:20
It also might be worth checking the anti dieseling valve on the carby if it has one. If the power is cut to this intermitantly it could cause the problem. Had a similar problem with my a12. Not sure if the A15 has an anti dieseling valve.
#5 Re: A15 cuts out
terryearl Posted on: 2011/11/15 7:05
changed wire to run from coil,starts fine but still cuts out
#6 Re: A15 cuts out
terryearl Posted on: 2011/11/15 7:07
yes has anti dieseling valve but that appears to be ok. i am begining to suspect ignition switch....any ideas how to by pass?
#7 Re: A15 cuts out
ddgonzal Posted on: 2011/11/15 7:33
Run a wire from the battery straight to the resistor. You'll have to remove the wire to stop the engine (or dump the clutch). This will allow you to test it.
