WTB: CA to 120Y caliper brackets
From A-TOWN
Chasing a set of caliper brackets, tried calling Kev Rowley but no answer, anyone have his mobile number or know of anyone else who make these?
Cheers,
Daniel
Posted on: 2011/11/16 23:31
Re: WTB: CA to 120Y caliper brackets
From A-TOWN
Bump
Posted on: 2011/11/20 23:14
From Brisbane
Hey mate
Probably your best bet is finding someone with a set off a car, can take them to a laser cutter to get copied.
I have them on my car but I'm not pulling it apart as I just sold it (I think - just waiting on money).
Cheers
NB: They will be the same as SR brackets I assume. Someone pls correct if I'm wrong but I understand that the struts are the same between CA and SR so therefore the bolt spacing and location must be identical & the difference is the shape/size of the caliper and rotor, rather than anything in the bracket/mounting.
Posted on: 2011/11/21 0:57
From Armidale N.S.W
Shifty is right about the SR CA brake thing cause i have used both with the brackets. but CA is better as far as fitting smallish rims. We have never had a problem getting hold of kev rowley. If your still hitting a brick wall in a week or so get in touch with me i can supply you a trace of a bracket you only need one as they can go on either side we will also supply a vernier caliper measurement of the thickness if you like then you can get them converted to cad drawings and laser cut.
Posted on: 2011/11/21 1:34
73 1200 wagon SOLD
From A-TOWN
Cheers for the info, if I can't find a set I'll def hit you up for the stencil.
Cheers!
Posted on: 2011/11/21 2:35
