Re: L16 Bottom with Z18ET Top?
Don't forget that the Z will have to lean the other way to the L series for inlet manifold clearence. That means Z sump, brackets and accessories. Once you are talking all that gear under the bonnet, 10KG isn;t that big a deal. You can save most of that in a custom exhaust manifold instead of the cast iron job.
Posted on: 2011/11/23 9:28
Subject Poster Date
     L16 Bottom with Z18ET Top? ruredi 2011/11/22 19:55
       Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/22 20:39
         Re: L16 Bottom with Z18ET Top? D 2011/11/22 23:50
           Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/22 23:54
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 0:14
               Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 0:18
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 0:59
         Re: L16 Bottom with Z18ET Top? L18_B110 2011/11/23 1:52
           Re: L16 Bottom with Z18ET Top? D 2011/11/23 4:12
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 4:34
               Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 4:45
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 4:25
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 5:07
         Re: L16 Bottom with Z18ET Top? D 2011/11/23 5:54
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 5:57
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 6:01
         Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 8:58
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 16:08
             Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 16:19
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 5:49
       Re: L16 Bottom with Z18ET Top? L18_B110 2011/11/23 6:51
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 7:15
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 9:24
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 9:28
       Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 10:13
       Re: L16 Bottom with Z18ET Top? D 2011/11/23 12:18
         Re: L16 Bottom with Z18ET Top? D 2011/11/23 12:58
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 21:26
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/23 22:16
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 22:26
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 23:18
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 3:35
           Re: L16 Bottom with Z18ET Top? D 2011/11/24 4:00
       Re: L16 Bottom with Z18ET Top? D 2011/11/24 1:13
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 1:47
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/24 1:23
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 1:45
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/24 2:07
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 2:38
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 3:46
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 4:25
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 5:01
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/24 5:30
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/24 7:52
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 8:07
       Re: L16 Bottom with Z18ET Top? grant76 2011/11/24 8:11
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 11:49
           Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 12:47
             Re: L16 Bottom with Z18ET Top? D 2011/11/24 13:40
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 21:20
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 22:05
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 22:08
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 22:55
       Re: L16 Bottom with Z18ET Top? D 2011/11/24 23:10
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/25 4:23
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/25 5:07
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/25 6:12
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/25 6:35
             Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/25 6:50
         Re: L16 Bottom with Z18ET Top? trb012 2011/11/26 0:09
           Re: L16 Bottom with Z18ET Top? D 2011/11/26 4:50
