Re: L16 Bottom with Z18ET Top?
Leigh I have to tell you i love this European you. But if your wearing a carry over your shoulder it's over lol.
I remember reading 21st century performance and the head in a l series turbo setup will mean squat, only if Your chasing every last pony. Thats why the large volume u67 head or whatever it is will be best, will drop compression a tincy bit to stave off detonation and allow allite more boost that may increase chance of det.
Lags has had ca, a series turbo and atmo, sr and also involved in marks 180b l20 turbo setups plus more!!! I tend to agree with him but all a series turns seem to suffer ring failure of some sort (ask 1200rc lol )
Easiest option would efi the a15 then work out a low boost set up for it. Higher comp good off boost and low psi will give it a kick... Won't be a ca ball tester but enough fun for you hopefully.
Posted on: 2011/11/23 22:26
Subject Poster Date
     L16 Bottom with Z18ET Top? ruredi 2011/11/22 19:55
       Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/22 20:39
         Re: L16 Bottom with Z18ET Top? D 2011/11/22 23:50
           Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/22 23:54
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 0:14
               Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 0:18
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 0:59
         Re: L16 Bottom with Z18ET Top? L18_B110 2011/11/23 1:52
           Re: L16 Bottom with Z18ET Top? D 2011/11/23 4:12
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 4:34
               Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 4:45
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 4:25
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 5:07
         Re: L16 Bottom with Z18ET Top? D 2011/11/23 5:54
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 5:57
             Re: L16 Bottom with Z18ET Top? D 2011/11/23 6:01
         Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 8:58
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 16:08
             Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 16:19
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/23 5:49
       Re: L16 Bottom with Z18ET Top? L18_B110 2011/11/23 6:51
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 7:15
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 9:24
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/23 9:28
       Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 10:13
       Re: L16 Bottom with Z18ET Top? D 2011/11/23 12:18
         Re: L16 Bottom with Z18ET Top? D 2011/11/23 12:58
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 21:26
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/23 22:16
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/23 22:26
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/23 23:18
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 3:35
           Re: L16 Bottom with Z18ET Top? D 2011/11/24 4:00
       Re: L16 Bottom with Z18ET Top? D 2011/11/24 1:13
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 1:47
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/24 1:23
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 1:45
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/24 2:07
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 2:38
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 3:46
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 4:25
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 5:01
       Re: L16 Bottom with Z18ET Top? revhead001 2011/11/24 5:30
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/24 7:52
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 8:07
       Re: L16 Bottom with Z18ET Top? grant76 2011/11/24 8:11
         Re: L16 Bottom with Z18ET Top? D 2011/11/24 11:49
           Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 12:47
             Re: L16 Bottom with Z18ET Top? D 2011/11/24 13:40
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/24 21:20
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 22:05
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/24 22:08
       Re: L16 Bottom with Z18ET Top? LAGWAGON 2011/11/24 22:55
       Re: L16 Bottom with Z18ET Top? D 2011/11/24 23:10
       Re: L16 Bottom with Z18ET Top? trb012 2011/11/25 4:23
       Re: L16 Bottom with Z18ET Top? ruredi 2011/11/25 5:07
         Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/25 6:12
           Re: L16 Bottom with Z18ET Top? ruredi 2011/11/25 6:35
             Re: L16 Bottom with Z18ET Top? Anonymous 2011/11/25 6:50
         Re: L16 Bottom with Z18ET Top? trb012 2011/11/26 0:09
           Re: L16 Bottom with Z18ET Top? D 2011/11/26 4:50
