#1 engine bogging down?
a12datto120y Posted on: 2011/11/26 3:08
hi i was just wandering if someone could explain to me why my engine bogs down as soon as the secondary starts to open for few seconds then picks up fine?
i have tried size 135 and 150 jets in the secondary but dosnt change much so i left in the 150 for better highend power.
Thanks!
#2 Re: engine bogging down?
ddgonzal Posted on: 2011/11/26 4:47
This is generally not a jetting problem, but usually caused by fitting the wrong size carburetor.
Are you using Hitachi DCG306? Which one?
#3 Re: engine bogging down?
orange-1200 Posted on: 2011/11/26 6:09
could be flooding while your at a constant speed so when u put your foot down it bogs downuntil it clears out.. my a14 had the same problem..
#4 Re: engine bogging down?
greendog Posted on: 2011/11/26 6:53
yes more info needed, by the sounds of it id say the vtec is broken:]
#5 Re: engine bogging down?
Posted on: 2011/11/26 8:44
#6 Re: engine bogging down?
a12datto120y Posted on: 2011/11/26 12:33
hahaha vtec.
yes its a stock hitachi carburetor i was just testing to see if it was the secodarys by sticky taping a 5 cent coin onto the mecanical weight to make it open up slower and it made the bogging alot less but not 100%.
thanks
#7 Re: engine bogging down?
Datsfullysik Posted on: 2011/11/26 12:37
Have you checked your fuel pressure? Maybe pushing fuel past the needle somehow?
#8 Re: engine bogging down?
a12datto120y Posted on: 2011/11/26 15:10
yer its a new fuel pump was somthing around 2.5 or 3 psi
#9 Re: engine bogging down?
greendog Posted on: 2011/11/26 16:28
what colour are the plugs?
1 more vtecyo ha
#10 Re: engine bogging down?
datsa73 Posted on: 2011/11/27 1:52
Put the bigger jet in the primary. I had the same problem. I have 190 in primary 's and 160 in the secondary's. My car bogged off the start and then picked up. Solved it by putting the bigger jets in the primarys. I run two carbs.
