possible vacuum leak??
From vic
hi i was wandering in your typical dcg306 carb the primary and secondary throttle shaft come out through under the jet plugs and i have just figured when i spray starting fluid thier the idle smooths out but in the primary side it seems thiers no leak.
so my question is should this area be fully leak free like 100% or is it normal to see a bit of an leak?
also this is a new carby i got from ebay.
thanks.
Posted on: 2011/11/30 7:46
Subject Poster Date
     possible vacuum leak?? a12datto120y 2011/11/30 7:46
       Re: possible vacuum leak?? ddgonzal 2011/11/30 21:07
       Re: possible vacuum leak?? edp 2011/12/1 4:54
