Re: Friday Night at the intersection
Razor wrote:
after 20mins and it started, idles fine but when I put it in drive or reverse engine stalls
B310GX
You are right in what you say, but his symptoms were the other way around. It would idle, but no more than that. I suspect that if it was left to idle long enough, the heat would have dried it out some & it would have been driveable. Who's to know at the time.
Ignition components should be regarded as a serviceable consumeable, & when the cap, rotor & leads start showing their age, then consign them to the garbage & fit new ones. I have hot pressure washed my engines many times & have never had a problem, but i always have ignition parts in "as new" condition. The glossy surface of new parts causes the water to ball & roll off like on a fresh polish & wax job. Old ones hold water like an oxidised paint job.
New caps & rotors are cheap, particularly when compared to the inconvenience & cost of a breakdown.
Posted on: 2004/3/8 11:51
Love your Datsun.
Treat it well.
« 1 (2)
