Re: Boksie 3.0 complete rebuild.
From Cape Town ZA
Ok so today I stripped the gearbox to see what's up in there. It kept jumping out of 4th when you decelerated in gear or just changed up and went into cruising mode.
To open the gearbox undo the bolts around the waist that goes through the sandwich plate.
Now the rear housing can come off, just give it a wiggle so the gear selector comes out of it's slot. When I opened it up the spring that holds the speedo gear in it's place was lying on the 5th gear, visible on the left set of gears. That explains why the speedo wasn;t working anymore, no idea how it unhooked.
To get the gearset out of the front housing, you need to remove the front bearing cover, undo all the bolts around it's edges.
When it comes of, there's two circle-clips holding the bearings in their positions, taek them off then the housing will come of.
The whole gearset then comes out and you have easy access to everything.
Here's the two gearsets I have. The lefthand one with the steel sandwich plate is the one I bought the gearbox with, I removed that when the selector broke after a very excited gear change at Killarney doing the 1/4, The one on the right is the one I took out of a gearbox we found at a scrap metal dealer, and has been doing duty without fail. Only thing is it jumped out of 4th, but after carefull measurements I found out why. The aluminium gearset must be from a W55 gearbox, because all the carrier bearings are narrower then the steel plated one's, so specifically the one on the main input shaft wasn't positioning the input shaft as far back as it should. That means when you hooked 4th, which simply locks the input and output shaft together for a 1:1 ratio, it didn't engage completely which would kick it out. There's some more reasona I found which makes the alu one a W55, read on...
Ok now I went ahead and counted some teeth. My mother always said, "sit jy alweer en tanne tel?", but I don't think this is what she meant...
Here is what I found, keep in mind that I bought the gearbox with the steel sandwich plate and replaced it with the alu one later on. Look at the chat below, I was going to do it with a calculator, but folded to the charms of Excel. In the right most column I included the ratios for the different gearboxes as from this page, http://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html, The ratios indicate which gearbox it is.
BLUE gear ratios, these are the ratios that were in the steel sandwich plate I bought the gearbox with. They correspond to the ratios for the W57, which means I must have bought a W57.
GREEN gear ratios, these are the ratios that were in the aluminium sandwich plate I bought. They are the same as the W55 ratios, and the fact that this gearset's carrier bearings are also narrower than the steel ones, affirms that this must be a "lesser" W55 gearset. It stil survived extremely hard launches as anyone who knows my car and saw me drive it can confirm. So a W55 is plenty strong, but obvisouly it'll konk out before a W57/8.
RED gear ratios, these ratios are a combination of the blue and green ratios. Now on these boxes the intermediate shaft is solid ie. the transfer gears for 1 through 3rd are part of the intermediate shaft as is the gear that meshes with the input shaft. Which means that if you want to change gear ratios for 1-3rd gear you also have to change the intermediate shaft and the input shaft. The only gear that is removable is the 5th gear, both on the intermediate shaft and the output shaft. Now the only difference between the W57 and W58 gearboxes are the 5th gears, with the 5th gear in the W58 being taller than the W57. So what I did is I plugged the 5th gear from the W55's numbers onto the input ratios of the W57, and what do you get? Yes that right, you get a W58, as can be seen in the right most column.
The gear calculation is, (Output/Intermediate)*(Intermediate/Input), going backwards through the teeth numbers in the sheet. So for the 1st gear of the W57 it would be (34/14)*(46/34)=3.286, and so on and so forth.
This means that I'll be re-fitting the steel sandwich plate but with the W55's 5th gear ratios installed, so that I have a W58. Only place this is going to make a difference is when you cruise the RPM's will be a bit lower, but also the W57/8 gearboxes' 1st through 3rd will be longer than the W55's.
My only concern now is that I've fitted that 3.3:1 diff ratio vs the old 4.3:1. I'm a bit worried that, that might be a bit to tall now. Let's see what the calculator says...
Posted on: 2011/12/5 12:04
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Subject Poster Date
     Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 8:10
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 8:18
         Re: Boksie 3.0 complete rebuild. D 2011/6/23 8:41
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 14:35
         Re: Boksie 3.0 complete rebuild. 1200GXman 2011/6/23 14:49
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/25 21:23
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/27 17:40
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/27 17:44
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/28 7:08
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/28 7:47
           Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/28 7:51
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/28 8:59
       Re: Boksie 3.0 complete rebuild. edp 2011/6/29 1:29
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/29 4:23
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/29 9:11
       Re: Boksie 3.0 complete rebuild. edp 2011/6/29 16:52
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/29 20:40
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:28
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:30
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:34
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:36
               Re: Boksie 3.0 complete rebuild. Anonymous 2011/7/26 22:03
                 Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 22:15
                 Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/26 22:18
                   Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 22:32
                     Re: Boksie 3.0 complete rebuild. Shoota_77 2011/7/26 23:41
                   Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/27 0:24
       Re: Boksie 3.0 complete rebuild. darrenwilson 2011/7/27 2:15
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/27 2:42
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/27 6:39
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/8 20:43
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/8 20:46
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/9 11:56
       Re: Boksie 3.0 complete rebuild. racetech 2011/8/18 11:10
       Re: Boksie 3.0 complete rebuild. iDatto 2011/8/24 12:12
       Re: Boksie 3.0 complete rebuild. racetech 2011/9/21 13:44
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:02
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:03
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:04
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:06
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:12
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:18
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:19
                 Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:20
                   Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:21
                     Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:23
                       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:24
                         Re: Boksie 3.0 complete rebuild. kululadotgroen 2014/1/30 13:23
                           Re: Boksie 3.0 complete rebuild. darrenwilson 2014/1/30 18:45
       Re: Boksie 3.0 complete rebuild. Shallots 2017/1/20 3:39
         Re: Boksie 3.0 complete rebuild. ddgonzal 2017/1/20 3:57
           Re: Boksie 3.0 complete rebuild. ddgonzal 2017/1/20 4:05
