Re: Boksie 3.0 complete rebuild.
From Cape Town ZA
I got some stuff done tonight, mainly on the engine, also started working out how to mount only the master for the brakes. I'm going to ditch the booster for now, if the brakes are to hard or not strong enough I'll fit it back.
Here's the solution I came up with for joining the pre-circulation pipes from the water pump to the top outlet. Used regular copper tubing, that's normally used for plumbing, and just soldered something up. Look at the edges of the pipe where I cleaned and applied some solder right on the edge to make a hump to keep the rubber pipe from popping off when the clamp is tightened and it starts taking pressure.
Then I just painted it black to make it blend in a bit better.
And a test fit. Shouldn't be to obvious from above.
I removed the master form the booster, and started to take some measurements for an adapter plate. I'll have that cut and fit the master so long. Came up with a good idea for the puch rod to actuate the brakes, had a brand new push rod from a VW Golf gearbox lying around(yes Gambit, another VW part), which I'll cut and use along with a allen bolt to make the pushrod with.
Posted on: 2011/12/5 12:12
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Subject Poster Date
     Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 8:10
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 8:18
         Re: Boksie 3.0 complete rebuild. D 2011/6/23 8:41
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/23 14:35
         Re: Boksie 3.0 complete rebuild. 1200GXman 2011/6/23 14:49
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/25 21:23
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/27 17:40
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/27 17:44
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/28 7:08
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/28 7:47
           Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/28 7:51
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/28 8:59
       Re: Boksie 3.0 complete rebuild. edp 2011/6/29 1:29
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/6/29 4:23
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/29 9:11
       Re: Boksie 3.0 complete rebuild. edp 2011/6/29 16:52
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/6/29 20:40
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:28
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:30
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:34
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 21:36
               Re: Boksie 3.0 complete rebuild. Anonymous 2011/7/26 22:03
                 Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 22:15
                 Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/26 22:18
                   Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/26 22:32
                     Re: Boksie 3.0 complete rebuild. Shoota_77 2011/7/26 23:41
                   Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/27 0:24
       Re: Boksie 3.0 complete rebuild. darrenwilson 2011/7/27 2:15
         Re: Boksie 3.0 complete rebuild. ddgonzal 2011/7/27 2:42
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/7/27 6:39
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/8 20:43
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/8 20:46
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/8/9 11:56
       Re: Boksie 3.0 complete rebuild. racetech 2011/8/18 11:10
       Re: Boksie 3.0 complete rebuild. iDatto 2011/8/24 12:12
       Re: Boksie 3.0 complete rebuild. racetech 2011/9/21 13:44
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:02
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:03
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:04
       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:06
         Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:12
           Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:18
             Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:19
                 Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:20
                   Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:21
                     Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:23
                       Re: Boksie 3.0 complete rebuild. kululadotgroen 2011/12/5 12:24
                         Re: Boksie 3.0 complete rebuild. kululadotgroen 2014/1/30 13:23
                           Re: Boksie 3.0 complete rebuild. darrenwilson 2014/1/30 18:45
       Re: Boksie 3.0 complete rebuild. Shallots 2017/1/20 3:39
         Re: Boksie 3.0 complete rebuild. ddgonzal 2017/1/20 3:57
           Re: Boksie 3.0 complete rebuild. ddgonzal 2017/1/20 4:05
