Re: s13 camber tops onto 1200 struts???
From mandurah
ok so i will need to shorten my struts for coilovers anyways ,will that fix the problem ? ,my ute has about 2 inch travel in the rear ,before the diff hits the rails ! so im not fussed about having enough travel to do jumps and stuff
also ,the honda coilover kits are cheap ,but they look to have plastic top spring perches ,am i seeing this right ?
so mik ,yours went straight on with a hotwire (shanked)wheel nut ,did it still need a spacer ? cos i got thousands of those wheel nuts
Posted on: 2011/12/14 15:27
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Took the washer off, check the thread as I think mine had different threads on them. I know old toyotas had right thread on them, damn shanked nuts.
Posted on: 2011/12/14 20:57
From gold coast aus
toyotas are 12x1.5 thread
Posted on: 2011/12/15 1:53
« 1 (2)
