Re: checking valve timing?
Look at it from above, sighting down along the gear faces.
Turn the engine back a ways, and then slowly forward (clockwise) until the cam dowl lines up with the centerline of the crank. That way the tension of the chain is drawn.
After that is done, look where the crank key is. Does it look like the black line or one of the red lines? It can only be off by a whole tooth, so it will be fairly obvious:
jpg  Timing_Chain_alignment_2.jpg (40.86 KB)
174_4eeaba8fc7535.jpg 640X560 px
Posted on: 2011/12/16 3:27
Subject Poster Date
     checking valve timing? a12datto120y 2011/12/15 7:59
       Re: checking valve timing? ddgonzal 2011/12/15 8:44
         Re: checking valve timing? a12datto120y 2011/12/15 8:53
         Re: checking valve timing? ddgonzal 2011/12/15 8:55
       Re: checking valve timing? a12datto120y 2011/12/15 9:00
         Re: checking valve timing? 1200rallycar 2011/12/15 11:05
       Re: checking valve timing? a12datto120y 2011/12/16 3:06
         Re: checking valve timing? ddgonzal 2011/12/16 3:27
       Re: checking valve timing? a12datto120y 2011/12/16 5:09
       Re: checking valve timing? bige 2011/12/16 5:25
         Re: checking valve timing? a12datto120y 2011/12/16 5:30
       Re: checking valve timing? bige 2011/12/16 5:31
         Re: checking valve timing? a12datto120y 2011/12/16 5:32
       Re: checking valve timing? bige 2011/12/16 5:33
         Re: checking valve timing? a12datto120y 2011/12/16 5:34
       Re: checking valve timing? bige 2011/12/16 5:35
       Re: checking valve timing? a12datto120y 2011/12/16 5:40
       Re: checking valve timing? ddgonzal 2011/12/16 5:52
