« 1 (2)
Re: High Beam = Fuse blown. Help with electrics?
I removed the projector lights that were in there, the side of the globe said 100/90w and the ones I have replaced them with are 55/60w. The second fuse down is still blowing.
This is the stock wiring, no relays installed yet.
If I join the circuit with something conductive in place of the fuse the lights will not illuminate and the spark is quite severe, it is almost certainly shorting out.
Posted on: 2011/12/18 9:31
In 1ks do the headlights form part of the ground in the circuit? So the projector beams are not conductive so forming a short?
Just an idea. Chris im as talented with elecs as you... Let our tard powers unite!
Posted on: 2011/12/18 9:51
We could nut it out but fir you png/sa types, that doesn't mean getting your nuts out or touching others nuts.... Mr t didn't mean get sum nuts like that.... Yours are slightly dark and chrmewy though
Posted on: 2011/12/18 9:55
Sounds like you are on the right track. Gotta find that short and unshortify it.
Start with elimination. Remove the headlights and flip the High Beams on. Still blow the fuse?
Pull the wiring connectors off (if the B10 has connectors) where the dash wiring goes through the firewall. Etc. Until you isolate it.
Because it's only the high beams, that means
* Headlights
* high-beam wires (RW red/white wires)
* Turn-signal/dimmer combo switch
* high beam indicator lamp in dash
There's not much else involved. One of those is likely to be shorted. It's unlikely to be the light switch, since the high beams don't work off that. It only feeds the dimmer switch. But there is a possibility it's shorting under heavier loads.
Posted on: 2011/12/18 9:58
Like dd says you have to go by process now, start at lights and work your way back at each terminal or plug ect try measure volts at fuse just in case, also as many ppl find out that many of the older cars run an earth circuit id also be looking at earths as well as it may just be something simple your not looking at! I've mad many mistakes with thing so simple :) good luck chris
Posted on: 2011/12/18 12:38
Car free
Quite a regular
I forget if those had "grounded" relays or "hot-side" relays
Little matter, check your grounds, especially the ones below the batt4ery..
Look for wire chafing around the headlight buckets and anywhere else.
If you installed aftermarket lighting, the relays may be drawing too much current, forgive me for rambling, it's almost 4 am here, and I'm very late to bed.
Rusty Wrench
Posted on: 2012/1/4 8:50
Good advice.
Datsun 1200 doesn't use any headlight relays, and so far so good on that, works as well as the Datsun 510s that have them, and more reliably than the 510s.
Definitely needed with dedicate power circuit if you go with high-power headlights.
Posted on: 2012/1/4 9:01
« 1 (2)
