1200 engine removal... i got some questions to ask!
Quite a regular
From Sunbury, Melbourne, Australia
hey guys. my datto ute is hot house green in colour but my engine bay is still the original white. how long would it take me to undress and remove the engine??? is there any concerns/complications i may come across? Your feedback will be greatly appreciated! Joel
Posted on: 2004/3/10 13:08
Re: 1200 engine removal... i got some questions to ask!
From Warwick, QLD
I've seen engines ripped out and back in, in no time,
since this is your first time naturally it's gonna take a little longer, juck remember where all the bolts came from and where all the wire went and you'll be fine, use tape and a marker if you are unsure
cheers
Damo
Posted on: 2004/3/10 13:16
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Thanx Damo
Quite a regular
my old man is a datto obsessed! me and my brother have 1200's and my old man has a 70mdl 2000 fairlady sports! he aint interested in helping me so i have to go solo! i just want to make sure i do everything properly. in all seriousness could you put a time limit on how long it would take to be removed??
Posted on: 2004/3/10 13:21
Re: Thanx Damo
From Brisbane
the time factor depends on your mechanical mindness/skill, your avaiable tools, a crane or block and tackle?, really comes down to experience and how many times you have taken Asereis (or any motor) out?
my first time on the A12 was intresting always good to have a experinced helping hand to guide you. but since then i have taken the A12 and A14 out a few times (fitted carbies, extractors etc etc) and is everything is quite easy and takes not long at all, after some inital learning
Posted on: 2004/3/10 13:41
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Canberra, Australia
It's good to take your engine in and out a few times, lets you test the strength of accelerator cables and starter motor cabling...
Posted on: 2004/3/10 14:52
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Okinawa, Japan
Yeah I stretch tested the accelerator cable on mine If I had to do it again in an un-detailed engine bay with an engine hoist I could probably get it out in about 45 minutes to an hour by myself but I'd have to be so careful now it'd probably take a couple hours. Without knowing your mechanical abilities it's impossible to tell but figure 3-4 hours MAX with a hoist.
Posted on: 2004/3/10 15:27
From Perth, Australia
2332 is pretty well right on the money. I only just this weekend did what you're talking about... I took out the A12, painted the engine bay and replaced it with a shiny new A14. I'd allow a few hours but the important thing is not to rush. It's better to take an extra hour now than have to come back later. Best of Luck !!!
Posted on: 2004/3/11 1:23
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
From WA
i whipped the L18 and four speed out of the 180B, changed the gearbox, and put it back in in about 2 hours. that didn't include draining the radiator, removing it, taking the battery out, unplugging the electrics, undoing the exhaust headers etc. i'd allow about another 2 hours for that, and about another 2 to hook it al up.
so yeah, half a day easy. get a mate to help with the engine itself though, it's a misson by yourself.
Posted on: 2004/3/11 2:48
