« 1 ... 17 18 19 (20) 21 22 23 ... 42 »
Re: 1200RallyCar - My road car rebuild - 1200 coupe
From Seattle ,WA.
Hey, what are you doing with my car out there???? It sure looks great going thru the paces.
Posted on: 2011/12/13 16:17
From Melbourne, Australia
did a compression test due to oil lifting into inlet system through breather system
got 170,180,180,155
dropped some oil into 155 (4th piston) and re-tested it went up to 165
what is most likely the issue? rings on 4th?
not sure what the result of the wet test would imply?
edit- just realised i did it stone cold, should i have warmed the motor first?
Posted on: 2011/12/28 3:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
:( should be no more that 15 difference between all cyl, rebuild for more boost mik
Posted on: 2011/12/28 9:43
Car free
From Ballarat Victoria
Unfortunatly, it does sound like time for a new set of rings at least.
Make sure when you are doing the comp test, the engine is spinning over just as fast for each cyl test.
If you can pick up another secondhand engine to freshen up, you might get away with driving this until the other one is ready to go in?
Posted on: 2011/12/28 19:41
VIC DYNO HIRE
might get it through engineering on this motor as im pretty close, but then i need to change engine number after engineering.... so that may not be worth while doing
i guess this rebuild is my chance to improve the internals a bit, so what should i be doing to the motor?
Posted on: 2011/12/28 22:07
1200 Coupe Rallycar
Just re ring and hone... The rest was ok.
Posted on: 2011/12/28 22:55
Bought a CA18DE auto s13 for a slab. Motor has good compression so may go CA18DE+T
. Cleaned out the inlet on the old motor and have been driving the car around anyway... It is going well.
Today I pulled out the aftermarket seats and welded some bracing to the seat mounts as the engineer requested. Also welded up a couple of rust holes in the fowl that were left over from the original restore/paint
So that leaves very little on the engineers list now, will have to book inspection soon!
Posted on: 2012/2/4 8:16
1200 Coupe Rallycar
Good work where's the pics
Posted on: 2012/2/4 8:41
Car free
front wheels or back wheels look better?
i have conceded that i will need to shorten my diff before i get my dream wheels (work equip 03)
but i have these to choose from as i won the ROH adrenalin on ebay for like $150 a few months ago
Posted on: 2012/2/18 12:08
1200 Coupe Rallycar
Rears
Posted on: 2012/2/18 12:31
Car free
