« 1 ... 17 18 19 (20) 21 22 23 ... 42 »
#191 Re: 1200RallyCar - My road car rebuild - 1200 coupe
edp Posted on: 2011/12/13 16:17
Hey, what are you doing with my car out there???? It sure looks great going thru the paces.
#192 Re: 1200RallyCar - My road car rebuild - 1200 coupe
1200rallycar Posted on: 2011/12/28 3:49
did a compression test due to oil lifting into inlet system through breather system
got 170,180,180,155
dropped some oil into 155 (4th piston) and re-tested it went up to 165
what is most likely the issue? rings on 4th?
not sure what the result of the wet test would imply?
edit- just realised i did it stone cold, should i have warmed the motor first?
#193 Re: 1200RallyCar - My road car rebuild - 1200 coupe
supafatto Posted on: 2011/12/28 9:43
:( should be no more that 15 difference between all cyl, rebuild for more boost mik
#194 Re: 1200RallyCar - My road car rebuild - 1200 coupe
sikyne Posted on: 2011/12/28 19:41
Unfortunatly, it does sound like time for a new set of rings at least.
Make sure when you are doing the comp test, the engine is spinning over just as fast for each cyl test.
If you can pick up another secondhand engine to freshen up, you might get away with driving this until the other one is ready to go in?
#195 Re: 1200RallyCar - My road car rebuild - 1200 coupe
1200rallycar Posted on: 2011/12/28 22:07
might get it through engineering on this motor as im pretty close, but then i need to change engine number after engineering.... so that may not be worth while doing
i guess this rebuild is my chance to improve the internals a bit, so what should i be doing to the motor?
#196 Re: 1200RallyCar - My road car rebuild - 1200 coupe
Posted on: 2011/12/28 22:55
Just re ring and hone... The rest was ok.
#197 Re: 1200RallyCar - My road car rebuild - 1200 coupe
1200rallycar Posted on: 2012/2/4 8:16
Bought a CA18DE auto s13 for a slab. Motor has good compression so may go CA18DE+T
. Cleaned out the inlet on the old motor and have been driving the car around anyway... It is going well.
Today I pulled out the aftermarket seats and welded some bracing to the seat mounts as the engineer requested. Also welded up a couple of rust holes in the fowl that were left over from the original restore/paint
So that leaves very little on the engineers list now, will have to book inspection soon!
#198 Re: 1200RallyCar - My road car rebuild - 1200 coupe
supafatto Posted on: 2012/2/4 8:41
Good work where's the pics
#199 Re: 1200RallyCar - My road car rebuild - 1200 coupe
1200rallycar Posted on: 2012/2/18 12:08
front wheels or back wheels look better?
i have conceded that i will need to shorten my diff before i get my dream wheels (work equip 03)
but i have these to choose from as i won the ROH adrenalin on ebay for like $150 a few months ago
#200 Re: 1200RallyCar - My road car rebuild - 1200 coupe
supafatto Posted on: 2012/2/18 12:31
Rears
