First gear is too steep for an A15 but not for and SR20DET --how do you figure? Even the mighty 5-liter uses a 3.35 first gear. Steeper the gear, the more acceleration.
The box it came from s15 are heavier cars and with the sr need better gearing for take off. Put it into a 1200 then
the first gear is overkill due to the weight.
2.9 is perfect for first with a powerful engine in a 1200.
If you prefer lower first, just just fit a lower diff. The 6-speed is still closer ratio than the Z box.
yes but geared for a heavy car and first gear is still not decent.
Lighter too. Smaller too. And since the SR boys need a stronger box, they are relatively available.
71B is lighter usually while C series are heavier but
6 speed is surely a little heavier than the C boxes.
Sorry for any confusion but was comparing 71b 260z box
vs 6 speed ratio box in terms of first gear ratio.
When you have tried the 2.9 first then you will see how
beautiful it is to accelerate away without quickly going
to the second gear. Its just a good setup and when I had
my 260z it just pulled away from traffic with ease with
the L28 just the factory SUS, extractors and higher comp.
Id love a 2.6 first with the rest of complimenting ratios
to suit that first but too expensive for a 60 series.
