« 1 2 (3) 4 5 6 »
Re: Another issue!!!!! Man
From Sydney, Australia
12v for optional clock light
Posted on: 2012/1/3 10:05
Makes sense, tracing curcuit board looked like power something
Posted on: 2012/1/3 10:08
Ok are these meant to be plugged together? Part of the loom into the ignition and indicator branch. Both black wires were taped up seperately but pins connect to for a ground bridge to somewhere I guess
I can find a bridge on diagram
Posted on: 2012/1/3 10:20
Tacho?
Posted on: 2012/1/3 10:55
Just find an earth point on the cluster, and run a wire to a clean earth temporarily.
Posted on: 2012/1/3 10:57
Did that connected those earths disconnected them- it's else where not under dash. Will drive to mech tomorrow bout knock and see if he Sus it out.
Other wise auto elec next week.... $$$$$ :(
Posted on: 2012/1/3 11:58
Problem still persists- noticed that as have internally regulated alternator, stock one removed, but there is no wire looped in the harness. Aren't you supposed to loop the ground pin and one of the others? There are only 4 wires into the 6 bladed plug???
Posted on: 2012/1/3 12:48
is it easy to change the temp sensors in the dash guage? or should i just put the good speedo stuff in the good dash with the broken speedo unit?
which evers easit would be best? coul ddrive round with a broken speedo if i had too
Posted on: 2012/1/3 14:35
It is very easy to change the Temperature Gauge, easier than changing the speedometer, which is also fairly easy. But why don't you test it first? See Temperature Gauge, Test/Troubleshooting section.
Posted on: 2012/1/3 20:02
Tested guage as per wiki, guage works, so mech says its the sender, said I replaced with a2nd hand spare and same thing. He says both prob shot.
The tapping noise is a noisey valve. And loose tappets/lash pads. Better loose than tight. He said valve should be ok but long term look at new head
Posted on: 2012/1/4 0:39
« 1 2 (3) 4 5 6 »
