speedo problem
From Goulburn NSW
Hi guys have a problem with my speedo,it jumps around wont sit still, can anyone tell me what may be the problem.
Posted on: 2012/1/12 8:15
Re: speedo problem
Disconnect the speedo cable and see if it spins freely when your driving slow in a car park. Is it only doing it at speed or even when stTionary
Posted on: 2012/1/12 8:32
Re: speedo problem
From Perth WA AUS
Or stop tapping your feet to the music :)
Posted on: 2012/1/12 8:40
Datsun 1200 2Dr sedan.
Re: speedo problem
You back on the beat nige? I thought you were a rumP shaker not a drum beater
Posted on: 2012/1/12 8:52
Re: speedo problem
From Perth WA AUS
I like to shake it all!
Maybe take the speedo drive gear out and check the gear and shaft if Miks suggestion does not work.
Posted on: 2012/1/12 8:58
Re: speedo problem
Could you elaborate how we should grab the shaft???? I'm sure your a master beater
Posted on: 2012/1/12 9:17
Re: speedo problem
From Sydney, Australia
Bad earth or old age causes the plastic liner to melt. Buy a new cable when everything else fails. You could puff some graphite powder down the inside or the cable, it might help.
Posted on: 2012/1/12 10:14
Re: speedo problem
From Goulburn NSW
Hi guys does anyone know where i can get a speedo cable from,preferably new.
Posted on: 2012/1/12 22:34
Re: speedo problem
Nissan or I got one made by speedscreen in Melbourne, $50 and was 300mm longer!
Posted on: 2012/1/12 22:36
Re: speedo problem
Try a local auto parts store -- all the L-series cables fit, just different lengths. Maybe $25. Made in china, but they work OK and seem to be good quality. They are only $15 here.
Posted on: 2012/1/12 23:13
