#1 How Can I post larger Images
UTE18L Posted on: 2004/3/13 19:33
when ever i make my images larger than what they are, look at them they suck, they are said to be to big to upload
Cheers Henry
#2 Re: How Can I post larger Images
ddgonzal Posted on: 2004/3/13 22:36
"too big to upload" is the file size, not the size of the picture.
For example, the picture size of this one is:
200x150 pixels (3% of one megapixel)
This one is:
100 x 75 pixels (0.0075 megapixels)
You need to start with a bigger picture, and do two things:
1. reduce pixel size (width x height)
480x320 is good for this site and is the size I normally use. I don't go bigger than 640x480 because it's too big for an 800x600 monitor when put into the web page. I normally don't go smaller than 320x240.
2. reduce file size
Use JPG format (like you did). But you can adjust the "quality" when saving it. Your graphics program may have a "quality" setting when saving it (or 'advanced' settings). I normally use 76% quality (medium) which looks great.
What photo software are you using to resize the pictures? We can give more specific tips.
#3 Re: How Can I post larger Images
2332owner Posted on: 2004/3/14 1:50
Yeah 640X480 is usually the go and I submit all the pics I've taken in that size.
#4 Re: How Can I post larger Images
UTE18L Posted on: 2004/3/14 4:21
thanks for that help, i was actually a 1st year graphic design student so i should know all this stuff.
I have photoshop but on my mac i have a program called iPhoto which i use to upload and store my photos on my laptop. to put them on the site i just export the photos to the desktop and then upload using datsun1200.com. I have a 4 megapixel camera and take my photos at A4 size. when ever i email pics i i do the same, and can get much larger pics.
Cheers henry
#5 Re: How Can I post larger Images
UTE18L Posted on: 2004/3/14 4:54
Reduced the photos to 640x480 and still no luck?????
#6 Re: How Can I post larger Images
ddgonzal Posted on: 2004/3/14 5:38
UTE18L, when you "export" a picture, does it give you a quality or advanced choice?
By lowering the quality, you'll lower the file size (but not the picture size). This is what needs to be done to make it fit on the site.
I'm not familiar with iPhoto, but maybe it has a Preferences or Options menu?
#7 Re: How Can I post larger Images
UTE18L Posted on: 2004/3/14 6:27
i know how to do it in photoshop but that requires exporting to desktop opening in photoshop then uploading to 1200.com. just takes that little bit longer. and i did reduce quality to a screen level of 72dpi but still nothing ????
#8 Re: How Can I post larger Images
ddgonzal Posted on: 2004/3/14 6:31
I should have said "JPEG Quality" or "Compression ratio" or "JPG compression". Screen or print quality isn't what's needed.
#9 Re: How Can I post larger Images
UTE18L Posted on: 2004/3/14 6:38
just tried to post a pic this is what i know,
Is was 640 x 480
the size was 900K
and it is 72 dpi
it still wont post??
Can i forward it to your email and see what you can do???
Thanks for the help
Henry Pallett
#10 Re: How Can I post larger Images
1200rallycar Posted on: 2004/3/14 6:48
it's too big
has to be less than 100kb!!
