« 1 2 (3)
Re: strut upgrade
Depends on what you want to do in the long run bud, if it's going to be a street car leafs will be good enough, ppl here have track cars still with leaf setup, im building a 1200 coupe for the track and will still run leafs, if your going to have BIG power and so on then I'd may e spend the extra and do a coilover setup in rear! I've looked around and some ppl leave one leaf in to locate diff and go coilover shocks which would be a cheaper way rather than 4 link!
But really up to what u want at the end of the day
Posted on: 2012/1/23 7:08
Car free
Re: strut upgrade
totally agree.
There are successful race 1200s with leaf springs. But then 4-link can be made to work well too (although it's easy to make a 4-link that doesn't work well). There are also successful big power cars with leafs.
It's like the old saw that double-A-arm suspension are superior to McPherson strut. Lo and behold it's usually true. But then Porsche makes strut suspensions that work just as well.
Posted on: 2012/1/23 7:54
Re: strut upgrade
With the way leafs can be played with these days to can make a big difference depending on the way you want thing setup! Shocks also make a big difference on the rear to so a good quality shock could make a big difference! Some people use tarago shocks and some ppl use a 4x4 shock, I've used heavy duty pedders shocks and have had no problems! There are a set of kyb shocks fs here they are good!
I'm yet to try Retrorallys setup in my coupe yet which is Bilsteins shocks and spherical bearings in leafs!
Posted on: 2012/1/23 8:06
Car free
Re: strut upgrade
From Sydney, NSW
something like this... dont need massive HP to warrant it do you?
http://datsun1200.com/modules/newbb/v ... ASC&type=&mode=0&start=80
Posted on: 2012/1/23 8:39
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
Re: strut upgrade
Not if u want to do it and want to spend the $$
Posted on: 2012/1/23 9:51
Car free
Re: strut upgrade
From Sydney, NSW
Only be spending money on the materials... got all the welding gear at work and I'm a decent welder lol
but its only a thought, a way of having full height adjusting rear :)
Posted on: 2012/1/24 3:06
« 1 2 (3)
