Re: R31 diff on a Datsun 120Y
From Adelaide South Australia
thanks for your help mate
Posted on: 2012/1/23 11:07
does the h165 just bolt right on or more shortening?
Posted on: 2012/1/23 11:09
Bolts in but tail shaft might need shortening only bout $100 to 200. Always try get the tail shaft with diff.
Posted on: 2012/1/23 11:16
and it has LSD with disks?
Phantom grip is a mod done to the diff center not the brakes. It's a spring loaded pack that "locks" the diff under load. It's considered the poor mans LSD now. At $450 I don't consider cheap but is compared to other lsds, but uf you get h165, topgear on here may habe done lsds left from his run of them.
Posted on: 2012/1/23 11:25
Ute diff is drum rear stock. You can mod to fit r31 rear disk brakes.
Posted on: 2012/1/23 11:26
Could go h165 with bluebird disks and a topgear LSD
Posted on: 2012/1/23 12:16
Car free
From Melbourne,Australia
Ive got a r31 diff in mine took a bit of work to get in there but let me know if you want pics or info
Posted on: 2012/1/23 21:21
« 1 (2)
