Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
starting another 1200 4age 20v
my_1200
Posted on: 2012/1/25 11:57
hey guys figured id start posting up a few things im doing to the new 1200 i have and hoping it gives me abit more motivation ill post up what im starting with
#2
Re: starting another 1200
demacoz
Posted on: 2012/1/29 20:53
You don't have much room,but at least you are out of the weather.
will it be a restoration or a conversion?
#3
my_1200
Posted on: 2012/2/9 10:53
absolutely no room at all but it will be out of there soon cause i gotta move.
#4
my_1200
Posted on: 2012/2/9 11:04
well made some more progress i've just put the front end back together. what i've done is shortened standard 1200 struts and i've put rx7 shocks on which are shorter and also has a larger shaft. i've done s13 brake which are all brand new and i have also replaced all pushed, ball joints, and tie rod ends. The wheels im using are 14 by 7 ssr witch are +15 offset, then to top it all off i body deadened the whole inner guards and holy #OOPS# is that stuff hard to get off but its all done now and doesn't look to bad. let me know what ya think
#5
Posted on: 2012/2/9 21:22
Nice, very nice. Is it driveable now? Let's see a road picture!
#6
my_1200
Posted on: 2012/2/9 22:04
Not just yet there is still a fair bit of work to be done to the rear end which its going to the panel beater in the next week or two.
#7
72DATSUN
Posted on: 2012/2/10 13:27
wow thats cool, can't wait to see the end result
#8
Shoota_77
Posted on: 2012/2/10 21:36
You're gunna hafta put a huge donk in it just to move the extra weight of the body deadener!
Sure beats cutting rust out though! I hope you cleaned up the rust underneath first cause it'll still rust away under the deadener. Other than that good stuff! Keep the piccies flowing......
#9
CA_1200_project
Posted on: 2012/2/10 21:47
good work i like the job you have done on break set up it shore is an upgrade from tiny stock brakes. Keep the build going and good luck
#10
my_1200
Posted on: 2012/2/11 3:59
Yeah there is a fair bid of body deadner but I've pretty much worked out if I use a 3 tubs of it max it's really only an extra 15 kilos which I'm not to fussed about. As for the engine I might upset a few ppl but im putting a 4age 20 valve something abit different hence the s13 brakes.
