How to repair loose bonnet frame?
From Malaysia
My bonnet frame came loose..
It will rattle during low idle speed...
Any idea how to do it the right way??
Thanks
Posted on: 2012/1/30 2:10
Re: How to repair loose bonnet frame?
From Seattle, WA
It was glued on by the factory. Use a seam sealer to repair it is the 'correct' way.
I wonder if a modern 2-part body epoxy would work?
Posted on: 2012/1/30 2:38
B110 sedan: L series and 4 speeds, the way they were
From Malaysia
Will the epoxy u mention a bit hard for the hood??
It will dent the hood if it is too hard, right??
Posted on: 2012/1/30 2:51
B110 1972 Modded A15
Use a seam sealer or panel adhesive... Check out upol website... U can get adhesives that set off in a few minutes or up to 60mins... Don't use a 2pack epoxy resin it wont fill the gap between the panels
Posted on: 2012/1/30 2:56
From Freo
Sikaflex Urethane...
Posted on: 2012/1/30 5:46
Email: BproAustralia@gmail.com
supplying Bprojects A Series and 1200 parts.
'68 Thou Wagon,(@the Paint Shop)
'67 Thou Wagon (to be lappo)
'69 2 door project,
A12A Project motor
A15 PSI Project Motor
'08 HD NighTrain 103ci 120HP
From RAdelaide
Agreed with Dundee , in black or white and can be painted over
Posted on: 2012/1/30 12:38
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From Seattle ,WA.
I used this Evercoat product but I wondered if one could get away with a standard urethane product like Sikaflex. The Maxim is a 2 part epoxy & paints just fine but its hard to get. The advantage of this over the 3M seam sealer was the tube, its a single cartridge to fit a standard caulking gun. The others (3M sausage tubes & other 2 part epoxy's) require special guns. It cures to a very solid state unlike conventional urethane which tends to stay flexible throughout its life.
http://www.evercoat.com/productCategory.aspx?cat=41
Dundee & srb210 - have both of you guys used single part urethane for that purpose before with success?
Posted on: 2012/1/30 22:42
From Freo
used it many times, awesome stuff.. used it to brace panels, stops drumming, (ie tin over a steel frame)
Posted on: 2012/1/31 0:23
'69 2 door project,
A12A Project motor
From Malaysia
Ohh ya...
I heard about the sikaflex thing b4...
Thanks guys...
Posted on: 2012/1/31 1:39
From Malaysia
Will Sikaflex 255 Extra corrode the bonnet??
Posted on: 2012/2/3 7:02
