Re: Lowering Blocks & Handbrake Cable
From Sydney NSW
ok so i was able to swap the backing plates, so the handbrake levers look to be in the perfect spot now!
few more problems though.....
the part of the rear handbrake cable that has the two wires running to the handbrake lever seems to be 30mm too short or so. Are there different lengths for different 1200 models?
next, i've fitted new brake shoes and springs and everything but have realised that the rear right brake setup is also missing one of the brake shoe adjuster hands, can you replace these parts? if so where can you purchase from? (see pics) also what tool is good to loosen the square brake shoe adjuster bit, small spanner? (also see pics)
think thats all for now!
jpg  1.JPG (105.76 KB)
12278_4f27a375d08e2.jpg 1037X692 px
jpg  2.JPG (129.85 KB)
12278_4f27a38211bbc.jpg 1037X692 px
Posted on: 2012/1/31 8:17
Edited by torin on 2012/1/31 8:32:45
Subject Poster Date
     Lowering Blocks & Handbrake Cable torin 2012/1/9 5:15
       Re: Lowering Blocks & Handbrake Cable Shoota_77 2012/1/9 5:22
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 6:10
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:51
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 7:22
             Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 7:36
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 7:46
                 Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 9:30
                   Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/9 13:48
                     Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/9 13:49
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:08
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:58
         Re: Lowering Blocks & Handbrake Cable ang94541 2012/1/9 7:21
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 23:32
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 5:14
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 5:31
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 5:56
       Re: Lowering Blocks & Handbrake Cable ang94541 2012/1/10 7:08
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 10:03
       Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 10:49
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 11:30
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 5:01
         Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 6:17
           Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 6:18
         Re: Lowering Blocks & Handbrake Cable ddgonzal 2012/1/12 6:20
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 9:48
       Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 9:53
         Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 10:07
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 10:13
         Re: Lowering Blocks & Handbrake Cable ddgonzal 2012/1/12 10:07
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 8:17
         Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 9:43
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/31 9:54
             Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 11:54
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/31 19:56
                 Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 3:36
                   Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/1 3:51
       Re: Lowering Blocks & Handbrake Cable edp 2012/2/1 4:26
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 5:23
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/1 5:48
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/1 6:52
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 8:49
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 7:04
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:11
             Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 9:14
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:26
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 9:48
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:51
           Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 10:05
             Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 2:34
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/3 3:24
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 3:27
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/3 4:20
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/3 9:55
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 10:15
           Re: Lowering Blocks & Handbrake Cable torin 2012/2/8 5:30
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/4 6:36
         Re: Lowering Blocks & Handbrake Cable Anonymous 2012/2/4 11:08
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/4 11:35
