Re: Lowering Blocks & Handbrake Cable
no - on the drums themselves,. There's the area where the shoes rub on, then there's a small area where the edge of the drum surface doesn't contact the shoes, and it doesn't wear down, leaving a lip or ridge.
http://datsun1200.com/uploads/photos/24173.jpg
Here's a rough diagram to help show it. I basically grabbed the first image I found on google and edited to suit. By pure chance the link happened to be to nissan brake drums (though I think perhaps not for a 1200!, but don't know for sure)
http://bonamotor.en.gasgoo.com/auto-products/1013954.html
I'll add another closeup of the original photo (a small section of it) because it shows on the 'new' drums there's actually a slight taper right on that edge to help the drum slip on easier. you could copy this, but i'd re-iterate that going too far will leave that edge thinner than ideal, esp if a roadworthy tester thinks it is how thin the rest of the drum is. So rather than copy that taper right at the edge of that new drum, put a slight taper or radius, a little less severe as that one.
http://datsun1200.com/uploads/photos/24174.jpg
Posted on: 2012/2/4 6:36
John McKenzie
Subject Poster Date
     Lowering Blocks & Handbrake Cable torin 2012/1/9 5:15
       Re: Lowering Blocks & Handbrake Cable Shoota_77 2012/1/9 5:22
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 6:10
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:51
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 7:22
             Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 7:36
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 7:46
                 Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/9 9:30
                   Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/9 13:48
                     Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/9 13:49
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:08
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 6:58
         Re: Lowering Blocks & Handbrake Cable ang94541 2012/1/9 7:21
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/9 23:32
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 5:14
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 5:31
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 5:56
       Re: Lowering Blocks & Handbrake Cable ang94541 2012/1/10 7:08
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 10:03
       Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/10 10:49
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/10 11:30
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 5:01
         Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 6:17
           Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 6:18
         Re: Lowering Blocks & Handbrake Cable ddgonzal 2012/1/12 6:20
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 9:48
       Re: Lowering Blocks & Handbrake Cable Anonymous 2012/1/12 9:53
         Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 10:07
           Re: Lowering Blocks & Handbrake Cable torin 2012/1/12 10:13
         Re: Lowering Blocks & Handbrake Cable ddgonzal 2012/1/12 10:07
       Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 8:17
         Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 9:43
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/31 9:54
             Re: Lowering Blocks & Handbrake Cable torin 2012/1/31 11:54
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/1/31 19:56
                 Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 3:36
                   Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/1 3:51
       Re: Lowering Blocks & Handbrake Cable edp 2012/2/1 4:26
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 5:23
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/1 5:48
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/1 6:52
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/1 8:49
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 7:04
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:11
             Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 9:14
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:26
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 9:48
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/2 9:51
           Re: Lowering Blocks & Handbrake Cable torin 2012/2/2 10:05
             Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 2:34
               Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/3 3:24
       Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 3:27
         Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/3 4:20
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/3 9:55
         Re: Lowering Blocks & Handbrake Cable torin 2012/2/3 10:15
           Re: Lowering Blocks & Handbrake Cable torin 2012/2/8 5:30
       Re: Lowering Blocks & Handbrake Cable jmac 2012/2/4 6:36
         Re: Lowering Blocks & Handbrake Cable Anonymous 2012/2/4 11:08
           Re: Lowering Blocks & Handbrake Cable supafatto 2012/2/4 11:35
