So why not remove the spacer? Or will the tyre hit the spring? 205s are a bit wide for the front.
205 tyre will not fit on the front without rolling/pulling the guard. And since you have Stanza struts you have slightly less room. In the photo above, the front tyres are sticking out.
Extreme negative camber can also help with front guard clearance.
Yeh the 10mm spacer is giving just enough clearence on the spring for it to roll freely. But rolling the guards is most certainly not an option since the car has been painted don't want to jeopardise the paint and maybe have it fracture.
The photo above is my car currently with the billet wheels. The wheels sit out both sides about an inch for both front wheels.
I will certainly take your advise and i think ill have to do some further research before i go jump in and buy some wheels.
I just need it to fit correctly with a set of wheels i like, which is the hard part.
