« 1 (2)
Re: Work Equip wheels
From Adelaide Hills
Adjustable lower arms and camber tops would help you pull them in, full lock would still be rubbing on the inside.
I get rubbing on the footwell with Sss stanza rim's with stanza strut cut down to R31 inserts, even with the radius rods pulled forward. Its hard to avoid.
Posted on: 2012/2/8 11:16
From Melbourne, Australia
work equip 03 = my dream wheel, one day i will buy a set, got quoted $1800 for the 4 at 15"
Posted on: 2012/2/8 11:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, Australia
I would run 15x7 +0 up front bout 15x8 +10 rear and deal with your suspension first so that the wheels will actually fit and look decent. Run a 175/50 tyre on front n 195/50'on back. Slam it and problem solved
Posted on: 2012/2/8 20:32
B110 sedan
« 1 (2)
