Re: Epoxy concrete sealer. Anyone done it?
From Adelaide
I used a water based poly-urethane to seal some furniture I made with second hand floor boards. It's a floor coating and was easy to clean up. Going ok for what I used it on but I don't drive on the furnature (yet). You don't need a respirator either, doesn't smell or give off fumes. I got it from Bunnings, about 100 for 4L
Posted on: 2012/2/7 9:53
From Ballarat Victoria
I was thinking of using the Epirez brand. I saw contractors using it at work.
They do a water based epoxy too.
http://www.epirez.com.au/index2.php?o ... c_view&gid=274&Itemid=183
Posted on: 2012/2/7 10:09
VIC DYNO HIRE
i dont know how many sqr mtrs you gotta do but 1hr pot life isn't great you'll be struggling to apply it after about 40 mins even with 10% thinners. i used some dulux luxa floor (similar specs to what you posted) just before xmas and at the 45 min mark it was like trying to apply super glue
Posted on: 2012/2/7 10:35
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From BlueMountains NSW
Gday if money is had to find like in my case ...i went to large paint shop and got couple tins 4lt oil base mistints (same colour) and did the workshop floor and garage. work a treat and easy cleaning. cheers Bazz
Posted on: 2012/2/12 6:18
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
I finaly got around to getting onto this. I ended up using surecote 200 HS, from Nuplex construction. I put the first coat on this morn, and i`ll do the second coat tomorrrow. I`ll put up some pics once its finished.
Posted on: 2012/5/18 6:27
VIC DYNO HIRE
From Armidale N.S.W
We used all white knight products Oil based heavy duty floor sealer needed near 15 litres to do 2 coats on my shed floor. So got 2 10 litre tins we used the etching solution first basically just hydrochloric acid then hit it. We also added the grip sand stuff to the first coat still gotta put a second coat on the front half without the grip sand in the paint for better adhesion. Will upload a pic i took on me phone later.
Posted on: 2012/5/18 6:43
73 1200 wagon SOLD
A couple of pics of the finished floor.Open in new window
I fixed the cracks in the floor by grinding them wider and filling them with body filler. The epoxy i used didnt need any primer and gave me plenty of time to get it down before it started to cure. I could walk on it after 24hrs.
I`m very happy with the product so far. $420 for a 20kg kit delivered to the door. I`ll have to see how it stands up after a few years of abuse!
Posted on: 2012/5/21 2:36
VIC DYNO HIRE
From Armidale N.S.W
Wow that looks great man very similar to mine colour wise.
Posted on: 2012/5/21 2:50
73 1200 wagon SOLD
It was called Koala Grey, I dont know how many Koala`s were used to get the colour right, But it looks OK.
Posted on: 2012/5/21 2:56
VIC DYNO HIRE
Wow what a dungeon you have there simon- the "oil " stains will wipe off much easier.
Posted on: 2012/5/21 6:07
« 1 (2) 3 »
