Glue for door seals?
What glue do I use for new door seals on my 1200? It clips in around the top and I need to glue around the bottom and the edges... Anyone recommend anything that has been successful?
Thanks
Posted on: 2012/2/19 13:31
Re: Glue for door seals?
From adelaide can post trim worldwide
contact cement used for gluing down carpet tiles you need to paint both surfaces then when tacky aprox 1hr later stick together
Posted on: 2012/2/19 13:44
I used clear silicone but probably not the best method.
Posted on: 2012/2/19 14:39
From Sydney, Australia
I used kwik grip n wait 5 min til tacky then put them together and put tape over them to hold them in place while glue dries
Posted on: 2012/2/19 20:10
B110 sedan
From Gold Coast
DYNAGRIP WEATHERSTRIP AND TRIM ADHESIVE.
Posted on: 2012/2/20 12:18
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
The old auto rubber places can sell you some, their red coloured contact glue is great.
Posted on: 2012/2/20 12:48
3M make the right stuff, from Scotch Tape to Sticky-Notes, they have a purpose made glue.
3M Weatherstrip Adhesive http://www.summitracing.com/search/?k ... herstrip%20Adhesive&dds=1
Posted on: 2012/2/20 21:49
From Canberra
You can pick up the 3M weatherstrip adhesive from any SuperCheap Auto/ Repco.
It cost me $18.00
Posted on: 2012/2/21 2:33
From Sydney
I know you haven't asked yet, But. If you get given the wrong door rubbers like i did or you are messy with the glue like I was. Don't spend weeks on trying to get it off with all sorts of stuff. PREPSOL will lift this stuff with ease, even when its cured.
I used the 3m and it worked well but it was yellow and you could see it. It looked $hit. Try get a black glue.
Posted on: 2012/2/21 5:59
From Perth WA AUS
Bailz is the car nearly done??
Posted on: 2012/2/21 10:18
Datsun 1200 2Dr sedan.
