measuring total Advance.
From vic
hi I want to measure how much my total timing is and i was reading in tech wiki that i can measure 39mm anticlockwise from the original mark on the pulley and make a mark and by 4800rpm it should line up with 0deg on the timing cover?
also to measure 39mm can i measure a non stretchy rope or somthing to 39mm cut it the wrap it on the pulley and mark the point?
also is the pulley on the 120y 138mm??
http://datsun1200.com/modules/mediawi ... #Total_Advance_Comparison
Thanks!
Posted on: 2012/2/20 10:12
Re: measuring total Advance.
From sydney.nsw
put a couple of timiing marks on pulley,u have std tdc from factory,then mark 1 at 10deg, then 20,then 30,then 40,and 50 btdc.then you can work it out.cheers
Posted on: 2012/2/20 11:29
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From vic
hi thanks but how are you supposed to mark degress on the pulley how do you know how far from TDC mark??
Posted on: 2012/2/20 12:18
From sydney.nsw
using factory mark put on tdc first zero on timing case, then turn motor back to 10deg on timing case, then re-make a mark where the zero is on timing case.do this every 10 deg's x5.
Posted on: 2012/2/20 12:29
That's a good idea. Plus you'll have marks every 10 degrees
Regarding the other method, rather than figure it out mathematically (360 degrees/circumference of the pulley) you could buy a timing wheel, ordered from your local auto parts store.
Posted on: 2012/2/20 21:43
