tow hooks??
wheres the best place ona 1200 to mount tow hooks, last time i was towed was a rope over front xmember..... guy wasnt keen so for track i need front and rear hooks.
rear i got tow bar if desperate.
id like to use conrods mounted to some where lol, or will just tie off ratchet strap webbing off tow bar and off x member
Posted on: 2012/2/20 12:19
Re: tow hooks??
From Nyngan, nsw Australia
all i did was just welded a length of 6mm round bar to the rear shackle, does the job....or make up a ringlet to bolt to the U bolt at the bottom...there plenty anhor points
Posted on: 2012/2/20 21:35
living is good,.....
Re: tow hooks??
For securing to a trailer? I put the straps through the wheels
or use factory Tow Hooks
Posted on: 2012/2/20 21:36
Re: tow hooks??
From Ballarat Victoria
Cool, ive never seen factory tow hooks on a 1200.
I cut about 600mm of webbing off a ratchet tie down strap(heavy duty). Got it stiched back onto itself and punched a couple of holes in it to go under the bumper iron.
Seems to look neat enough, with only a small loop that hanges out the front. It can be tucked up under the bar when you`re not on the track. You can do the same at the rear, but get the webbing stiched into a loop instead of back onto itself. Unbolt one of the rear spring hangers and slide it over.
You will have to pay an upholsterer to do the H duty stitching.
Otherwise im more than happy to make some up for you if you like.
Posted on: 2012/2/20 22:41
VIC DYNO HIRE
Re: tow hooks??
I should have clarified, for track use. I saw some strap type points that bolt to car, just need to find a point they won't rip chasis or suspension mounts
Posted on: 2012/2/20 23:06
Re: tow hooks??
That's what I'm talking about simon. What kind of cost were they to have made up??
Posted on: 2012/2/20 23:08
Re: tow hooks??
From Sydney
The factory tow point on the front is around the castor rod mount. The mount is pressed rounded above the castor rod as not to cut the rope etc. I do like the factory offering of the bolt on brackets though.
Posted on: 2012/2/20 23:47
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: tow hooks??
An upholterer owed me a favour, so cost nothing.
The front one is sandwiched between the bumper bracket and the rail. You have to punch two holes in it to match the bolts spacings of the bumper bolts.
I`ll get some done for you today if you like. Wont cost anything if the upholterer doesnt charge me. Just tell me if you want 1 tonne or 3 tone rating.
Posted on: 2012/2/20 23:58
VIC DYNO HIRE
Re: tow hooks??
I'm a bit on the heavy side so heavier better most likely. Cheers
Posted on: 2012/2/21 0:18
Re: tow hooks??
Half done, now off to get them sewn up. Hope you like blue!
Posted on: 2012/2/21 0:33
VIC DYNO HIRE
